Connection
Keywords: Thomson | 585v7 | 585 | | hardware | router | setup | broadband | wireless
Summary: How to change the default password on a Thomson 585v7
If you got your router before Dec 2008 you shouldn't need to take any action. If you visit http://192.168.1.254/ and are prompted for a username and password then the security flaw does not apply to you. You are already safe from the reported vulnerability and you need not take any action. To change the default password on a Thomson 585v7 Follow these simple steps.
The next time you browse to 192.168.1.254 you'll be asked for your username and new password. You'll need to enter Administrator as the username. Please Note:
Should you experience any problems with your Thomson 585v7, please Contact our Support Team. This page last updated 5th September 2009
Has this page helped you solve your problem? Your feedback helps us to improve the help we provide.
Please note: We
cannot reply to individual feedback through Rate My Page. If you need
more help with a problem please use the Help
Assistant. Other customers will be happy to help you with most issues
at the Community Site
Forum.
RELATED ARTICLESSearch help pages
Browse A-Z help index
