Summary: All the details you'll need to get connected with Plusnet broadband.
Select your provider?
Our website now provides help and support to customers of Plusnet, Force9 and Free-Online. Please select your provider using the drop-down menu and you will be provided with the technical support details that are appropriate to you.
  1. Broadband connection settings
  2. Fibre broadband connection settings
  3. Where and how do I enter these settings?
  4. I can't get connected
These are the settings you'll need to connect to our broadband service with a compatible router. (Note: if you need fibre broadband connection settings see point 2).
The terms used for these settings can vary, depending on the make and model of your router. We've included the most common alternatives below.
Connection Settings
Broadband Username/Login name username@plusdsl.net
Connection Type / Encapsulation PPPoA /PPP over ATM
Password The password you use to log in to this website
Virtual Path Identifier (VPI) 0
Virtual Channel Identifier (VCI) 38
Multiplexing method VC Based / VCMUX / VC-Multiplexing
Please note:
  • The above table has everything you'll need to get connected with any ADSL compatible broadband router
  • Some routers may ask you to enter other settings not mentioned above, you should be able to leave these as default or blank
  • If your Plusnet broadband was activated before August 2002, your username may be username@plus.net rather than username@plusdsl.net
  • Former Affinity Broadband customers will need to use username-pn@aihpipe.co.uk
[Top]
You'll need the settings below if you're connecting to our fibre broadband service with your own fibre-compatible router. To connect with a fibre router we've supplied please follow our install guide.
Note: the majority of broadband routers won't work with fibre broadband. Most cable routers will work if they can use PPPoE and have an Ethernet WAN port, however we can't provide support if you have problems.
Connection Settings
Connection Type / Encapsulation PPPoE Always On
[Top]
If you're setting up a router supplied by Plusnet, our Router guides will help you with this.
If you're using a router you've purchased separately, please refer to the documentation provided with your router.
[Top]
If you're able to connect elsewhere, use our Broadband troubleshooter to report a problem or contact our Support Team.
You may also find our Broadband connection problem guides helpful.
[Top]
This page last updated 19th April 2011
Did you find this page helpful?
Yes No Maybe
