Skip to main content
Your basket
Monthly payment
  • every month for months, then
  • months contract
  • no annual contract
Monthly payment total
£xx
One-off payment
One-off payment total
£xx
Included with your package
Summary
Monthly payment
    One-off payments
    Reward Card included
    to say thanks for signing up
    Amazon gift card
    cashback icon
    Today's payment
    Today's payment
    Connecting to your WiFi network with Windows 11
    Connect your Windows 11 computer to your Plusnet router with the help of our FAQs.
    Windows 11 WiFi FAQs
    You'll find both of them either on a sticker on the bottom or back of your router or on a pull-out tab at the back.
    If you're connecting to the Internet using one of our routers, the SSID will look something like this: PlusnetWirelessABC123 or PLUSNET-Z258.
    Your wireless password is made up of ten numbers and letters.
    1. Select the Network icon on the far right of the taskbar to open quick settings.
      The Disconnected icon will show when you’re not connected.
    1. On the WiFi quick setting, select Manage WiFi Connections >
    1. Then select the > icon next to the WiFi quick setting to see a list of available networks.
      Choose the WiFi network you want to connect to, then select Connect
    2. Type the security key (often called the password).
      Remember, your password is case sensitive so if you're having problems, double check what you're typing.
    3. Follow additional instructions if there are any.
    Was this article helpful?
    More ways to get help
    Plusnet community
    Talk to our community
    Contact our team
    Or call 0330 1239 123
    My Account
    Sign into Broadband
    Sign into Mobile
