Connecting to your WiFi network on an iPhone or iPad
Here's all you need to know to connect your iOS device to your new router.
Apple iPhone/iPad WiFi FAQs
This guide will show you how to connect an iPhone or iPad to a wireless router supplied by Plusnet. You should be able to use it with other wireless routers as long as you know the Wireless Name (SSID) and password of the network you're connecting to.
You'll find the Wireless name (SSID) and password on a sticker on the bottom or back of your router or on a pull-out tab at the back. If you're connecting to the Internet using one of our routers, the SSID will look something like this: PLUSNET-1A2B3C or PlusnetWireless1A2B3C.
Your wireless password (wireless key or WPA PSK) is made up of a series of numbers and upper and lower case letters.
- Tap the Settings icon
- Tap the WiFi option
- If WiFi is switched off, toggle the switch to turn this on. You'll see a list of networks you can connect to. Select your router's Wireless name (it'll start with Plusnet).
- You'll be asked for the password. This is the Wireless key (or WPA-PSK key) shown on the bottom of your router. Enter the key and tap Join.
Having problems with this step?
- Your wireless key is case sensitive, watch out for upper and lower case letters
- Watch out for 0, that's a number zero rather than a letter O
- You're now connected to your wireless network. Open your web browser to start browsing!
If you want to check your connection, the WiFi symbol at the top right of your screen shows what's going on. The bars on the icon indicate the signal strength. The WiFi option in Settings will show the name of the network you're currently connected to.
More ways to get help
Plusnet community
Talk to our community
Contact our team
Or call 0330 1239 123
Sign Language service
Contact us using British Sign Language
My Account
Sign into Broadband
Sign into Mobile
